LCD am Parallelport
LCD am Parallelport
Neuer Beitragvon Thomas am Donnerstag 13. März 2003, 12:04
Hier mal eine Kurze Beschreibung wie man ein
LCD Display an den Parallelport des Computer anschließen
kann um dort viele Interesannt Infos anzuzeigen.
Die Software kann z.B.
    jaLCDs features:
    -high speed data transfer to the display
    -easy-to-use configuration utility
    -doesn't use up too many resources
    -high stability
    -transition effects and many other graphical gimmicks
    -able to interface to a fli4l-Router
    -able to show more information than any other LCD program available
    -multiple configuration support, the configs can be changed at runtime
    -direct screen control (able to jump to any screen immediately)
    -TCP-IP-Interface for remote administration or as an interface to addon programs
    -flexible language to make your display do whatever you want
    Able to show information about:
    -CPU speed
    -CPU load
    -RAM-size/free RAM/used RAM
    -harddisks free/used/total
    -current date/time
    -uptime
    -each single process on your computer (RAM usage, CPU usage)
    -upload/download speeds (separately for each NIC or a total value for all NICs)
    -up/downstreamtraffic (separately for each NIC or a total value for all NICs)
    -up/download speeds reported by a fli4l-router
    -temperature/fan-rpm/voltages from Mainboard Monitor 5
    -e-mails from up to five accounts
    -Winamp information
    -distributed.net RC5-stats
    -seti@home-stats
    -Winamp-Spectrum-Analyzer
    -Winamp-Stereo-VU-Meter in 6 different Designs
    -Winamp-Song-Position-Bar in 7 different Designs
    -Heise-News (german)
    -Shortnews-Ticker (german)
    -Easy-Mod.de-Newsticker (german)
    -information about 5 Half-Life/UT/Q3A-gameserver
    -program of 15 TV stations (german)
    -and much more...
weitere Plugins und Infos und Download der Software auf: http://www.jalcds.de
Hier der Schaltplan:
Thomas
Forengründer
Neuer Beitragvon Thomas am Samstag 15. März 2003, 09:06
Weitere Infos und Platinenlyout siehe:
http://transistornet.de/viewtopic.php?t=619
Thomas
Forengründer
