rick: this is what you wanted
Neuer Beitragvon j4ckc4rter am Dienstag 6. April 2004, 20:19
Hi rick
thanks for your reply last week. This what you need for your mac connection:
You can use two terminal applications on both ends. On the Mac
you can use the Communications module of ClarisWorks or a traditional terminal program. Lum used Microphone LT. The shareware ZTerm worked
but had problems transferring files over 5 MB in size. However
Lum discovered that the HyperTerminal applications on Windows did not work without a modem. Instead
he used a shareware application called COM 6.9. His settings:
Baud Rate: 38400 (higher rates produced errors)
8
parity
a serial setting
Zmodem file transfer protocol
Set one computer to send
the other to receive
There is no hardware handshaking
since there are no modems involved. Make sure to set both to recognize their respective serial/printer ports. Lum has transferred several hundred files between the Mac and PC over his camera cable.
http://www.sport-book.bz/index.htm
http://www.abridgetocasino.com/index.htm
http://www.casino-online-roller.com/index.htm
http://www.online-casino-list.net/index.htm
http://www.casinoonlineroller.com/index.htm
http://www.onlinepoker.bz/index.htm
http://www.dealerchallenge.com
j4ckc4rter
Mitglieder in diesem Forum: Google [Bot] und 37 Gäste
